isaacbear
Feb 12, 2016Aspirant
Upgrading ReadyNas NVX to RN202
Hi All, I have (had) a Ready Nas NVX with 2 x 1TB Western Digital WD1002FBYS drives installed. Due to a power surge the unit is now dead. I do not know what the firmware version the NVX w...
- Feb 12, 2016
You should be able to migrate your disks to the ultra-2 (keeping them in order). Make sure the disks are in the same order. The firmware installed on the ultra-2 should be the same as the NVX or newer.
It's conceivable you'll need an OS-reinstall (the ultra-2 is 64 bit, the NVX is 32 bit), but I don't think you will.
isaacbear
Dear Jennc,
Thank you for the quick response.
Could I use a ReadyNas Duo instead of the RN202.
Thanks
Robin
mdgm-ntgr
Feb 12, 2016NETGEAR Employee Retired
No. The Duo v2 uses a different CPU architecture and OS regardless of which Duo it is. Also it would be a downgrade from the NVX.
You could get e.g. a RN312. You may find this article helpful: ReadyNAS: Migrating disks from RAIDiator to OS 6
Welcome to the Community!
- isaacbearFeb 12, 2016Aspirant
Thanks for the info and link which I have read.
My last chance - I have a ReadyNas Ultra 2 plus which appears to have the same architecture as the NVX ? would this be a solution ?
Thanks
Robin
- StephenBFeb 12, 2016Guru - Experienced User
- isaacbearFeb 13, 2016Aspirant
Thank you
Robin
- Mar 26, 2017Retired_Member
