gglaze1
Nov 01, 2012Aspirant
UPS for ReadyNAS 6 + ReadyNAS Duo
Hi guys, This forum seems to have loads of info, but also way too much info! I've searched around but can't find the answers I need. I'd like to get a UPS for my pair of ReadyNAS devices. I have: ...
Nov 02, 2012Guru - Experienced User
The CyberPower units appear to be a lot cheaper in the US.
My units indicate the power draw on their LCD panel - if APC has a model in your budget that does that it is a handy feature. Then if you discover the load is higher than you thought you can get a second unit later on.
Yes. Also keep in mind that the drives can take a lot of the power. You can probably find what the Hitachis use if you google on the drive model, if I remember correctly they used more than average.
mdgm wrote: I'd base it off typical usage. See the Comparison Charts
Do allow some extra for the router/switch and for usage going above typical levels. Also for optimal battery life you shouldn't load the UPS over 80%
