gglaze1
Nov 01, 2012Aspirant
UPS for ReadyNAS 6 + ReadyNAS Duo
Hi guys, This forum seems to have loads of info, but also way too much info! I've searched around but can't find the answers I need. I'd like to get a UPS for my pair of ReadyNAS devices. I have: ...
Nov 02, 2012Guru - Experienced User
I have a pro-6 located with my network core (2 routers - FIOS Actiontec and a high-end Netgear R6300, and a 24 port GS724 switch). All are on the UPS, which says the current draw is 89 watts. I can't tell the split, but I am sure that most of this is from the NAS.
In a different part of the house I have an NV+ and a Duo (both v1). The current draw is 56 watts.
All three NAS are fully loaded with disks.
Note you can set the power-down thresholds (at least you can on the V1 and x86 products). That can help ensure that the router stays up longer than the ReadyNAS.
