Keith_Cocker
Sep 21, 2011Aspirant
UPS Monitoring
Hi, I have a Readynas NV+ connected via USB to a Belkin UPS. It shows as connected in RAIDar. It shows as a Belkin and says 100% 2 minutes. The front panel of the NV+ shows it connected and in the pow...
Sep 21, 2011Guru - Experienced User
My ReadyNAS systems all have a "Select shutdown on battery low threshold:" option in the power section, with a pull-down set of choices.
Keith Cocker wrote: Hi, I have a Readynas NV+ connected via USB to a Belkin UPS. It shows as connected in RAIDar. It shows as a Belkin and says 100% 2 minutes. The front panel of the NV+ shows it connected and in the power section of Frontview its says that it is physically monitoring a UPS. BUT below that in Frontview there are no options (like I have seen in the manual etc) to choose what happens when power is cut i.e. no selection of percentage or auto etc. Is this correct or do I need to make some change or adjustment. With things as they are what will happen in the event of a power failure? Thanks for any advice.
2 minutes seems a bit short.
