rcolman
Jun 24, 2015Aspirant
UPS Recommendation for ReadyNAS 204
Please recommend a model for my newly acquired 204. TNX. Rick
mdgm-ntgr
Jun 24, 2015NETGEAR Employee Retired
Don't need that much runtime to shut the NAS down safely. Allowing a minute or two for the NAS to shutdown would be plenty. Also, you don't want to put more than 80% load on the UPS or else the battery will drain too quickly.
So it depends on how much runtime you want which model you get.
