rcolman
Jun 24, 2015Aspirant
UPS Recommendation for ReadyNAS 204
Please recommend a model for my newly acquired 204. TNX. Rick
vandermerwe
Jul 03, 2015Master
APC has a product selector tool on their website.
The entry level units are fine but have a year less warranty.
Smart UPS are not cheap compared to the Back-UPS range. These cheaper ones with USB monitoring have RJ50 to USB proprietary cables which can be problematic and are expensive to replace. The smart ups units will accept a standard device to USB cable.
There are other manufacturers of UPS devices.
I doubt you'll get a specific device number from anyone, it depends on where you live, prices locally, your current and future load, warranty requirements.
I also believe it helps do do your own research, you have a better understanding of what you are buying.
- Apr 03, 2016Retired_Member
