bishoptf
Jul 05, 2012Aspirant
USB 3 Drive Compatibility - Verbatim
So I have 2 verbatim store and go usb3 drives that I have purchased and having some issues with the unit detecting the drives. I still need to do some more testing but with the other drive but the on...
PapaBear1
Jul 05, 2012Apprentice
Not all USB drives are compatible with all ReadyNAS devices. Although formatting the drives NTSF won't keep the Pro2 from recognizing the drives, it will cause slower file transfer speeds than if they were formatted either FAT32 or EXT.
Have you tried all the ports on the Pro2?
Have you tried other USB drives (including flash drives)?
