aniraghome
Dec 22, 2020Tutor
USB HUB 3.0 with two external HDD
Model readynas 314 i have been using one usb to connect to UPS and utilizing second USB 3.0 port to connect to two external HDD's with a USB 3.0 HUB. it connects and both ext HDD are visible but, the...
aniraghome
Dec 22, 2020Tutor
Usb hub doesn’t have a power cord it just powers through usb port on nas. Similarly ext hdd are powered though hub.
I dont remove the ext hdd’s at all they always stay connected with nas via the hub. This is because i have daily backup jobs between nas to ext hdd’s.
When i had one ext hdd i use to directly plug it to one of the nas 3.0 ports directly all the time. Never had issues in 6 years. I started getting this issue only after the hub split that too the first ext hdd connected doesn’t have issues its the second one that gives the error.
mdgm
Dec 22, 2020Virtuoso
It could be an intermittent problem with supplying enough power for two drives. You could try switching to an AC powered USB3 dock and see if that helps.
If you download the logs what is the date in bios_ver.log?
- mdgmDec 22, 2020Virtuoso
I meant AC powered USB3 hub.
The reason I ask about the date of the BIOS is that there was a USB3 F/W update in newer BIOS from late 2013.- aniraghomeDec 31, 2020Tutorsorry for the delay. i downloaded the logs and the date i see in the file bios_ver log is 11/05/2013
- mdgmJan 01, 2021Virtuoso
From memory that is the latest. I thought the problem was most likely not supplying sufficient power to the drives or a hardware issue with the drive or hub anyway. See if you still have the problem with an AC powered hub.
- aniraghomeDec 23, 2020TutorWhere can i find “date in bios_ver.log“
- StephenBDec 23, 2020Guru - Experienced User
aniraghome wrote:
Where can i find “date in bios_ver.log“Download the full log zip file from the logs page in the web ui. bios_ver.log is in there.
