ipb_uk
Aug 16, 2021Aspirant
USB on RNDP6000-v2
Does anybody know if there is a size limit to connecting a usb hard disk to the front and back usb slots? Also can I connect a usb disk to every usb slot at the same time? Is there any difference to s...
- Aug 16, 2021
ipb_uk wrote:
Does anybody know if there is a size limit to connecting a usb hard disk to the front and back usb slots? Also can I connect a usb disk to every usb slot at the same time? Is there any difference to slots 1 & 2 at the back and front? Thanks Ian B.No limit I am aware of, and you can plug in multiple disks. All the ports in the Pro-6 are USB-2 ports, so the speed won't be the best.
Aug 16, 2021Guru - Experienced User
ipb_uk
Thanks Stephen.
