btwixt
May 24, 2022Guide
USB Recovery and boot menu > memory test with reference to OS updates and making bricks.
Reference: Re: RN102 unresponsive after initiating FW update from 6.10.6 to 6.10.7 Followed directions at this link: https://kb.netgear.com/29952/How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNA...
May 24, 2022Guru - Experienced User
btwixt wrote:
In the section "To boot your desktop model ReadyNAS from USB:"
first it says hold the Backup button. Then for 2-bay models it says to hold the Reset
button. Must be an error because the Reset button takes you to the boot menu.
Agreed. I think it is intending to tell you to hold the backup button for 30 seconds instead of 15. Though if you have a USB drive that has an activity light, that will tell you when the NAS begins booting from USB.
btwixt wrote:
Extra Credit Question: On the back panel is a small sticker near the Ethernet port. It covers a 4-pin header.
What is it for?
If you have a suitable adapter, you can connect the header to a serial port on the PC, which will give you console access w/o needing ethernet.
- btwixtMay 24, 2022Guide
Please satisfy my curiosity on two points:
1. What is the expected response to entering memory test from the boot menu?
2. Why has this twice before asked question been entirely overlooked?
Is this some jealously guarded intellectual property info?
- StephenBMay 24, 2022Guru - Experienced User
FWIW, I answered it here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/RN102-unresponsive-after-initiating-FW-update-from-6-10-6-to-6/m-p/2226523#M48652
https://kb.netgear.com/25629/ReadyNAS-OS-6-RN102-Memory-Test-Analysis?article=25629
- btwixtMay 24, 2022GuideI'll go clean my glasses.
Thank you for the quick reply
