stgeorge's avatar
Jan 03, 2014
USB ver ?
Can anyone help me identify which USB format the front "Backup" USB port is configured to on both a Pro6 and on an older Duo ?
Thanks
  • StephenB's avatar
    Do you mean disk format? The port itself has no format.
  • OK- options might be USB 1.1 or USB 2.0 or USB 3.0 (SS) or USB 3.1 (SS+)
  • StephenB's avatar
    All USB ports on the pro6 and the duo v1 are USB 2.0. And their actual performance with USB 2.0 drives is slower than a normal PC.
ProSupport for Business
