easytherm
Jun 25, 2016Aspirant
using a NAS RN102 both as a DDNS ftp server and a local network drive. Is that possible?
Hello everybody I installed about 2 years ago a RN102 NAS at my home in order to have a couple of my websites (remotely hosted) send a daily backup to my NAS. I managed to enable ftp access with...
- Jul 02, 2016
Thanks a lot,
I'll definitely will transit over a gigabit ethernet switch.
I'll ask my other questions over another thread
Jun 27, 2016Guru - Experienced User
easytherm wrote:
Before I search further, I have a question: Is this kind of service (both and simultaneous ftp access and network file server) correct for such a device? (RN102)
Yes. And of course you should be able to schedule the FTP backups during times when local access is light.
What speeds are you seeing?
- easythermJul 02, 2016Aspirant
Hi StephenB and thank you for your response.
I upgraded my NAS to raid (using now 2 HDD)
when I do a backup from an external USB drive connected to my laptop, using Syncbackpro, the speed seemsto be slightly above 5 Mbps. I'm on wifi.
Does this sound correct?
- StephenBJul 02, 2016Guru - Experienced User
What speed are you seeing with speedtest.net?
Also, do you mean 5 megabits per second or 5 megabytes per second?
Hi,
I'm connected locally to the NAS (which is at my home)
when connecting to my NAS over Wifi, I get about 5 megabytes/s, when a connect with cable ethernet, the speed rises to slightly less than 10 megabytes/sec
using speedtest i see an internet download speed of 27 megabytes/s and upload speed of about 6.5 megabytes/s
I have another question ;-), but let's close this case first. Do you think the above speeds are correct for this device?
