easytherm
Jun 25, 2016Aspirant
using a NAS RN102 both as a DDNS ftp server and a local network drive. Is that possible?
Hello everybody I installed about 2 years ago a RN102 NAS at my home in order to have a couple of my websites (remotely hosted) send a daily backup to my NAS. I managed to enable ftp access with...
- Jul 02, 2016
Thanks a lot,
I'll definitely will transit over a gigabit ethernet switch.
I'll ask my other questions over another thread
Jun 27, 2016Guru - Experienced User
easytherm wrote:
Before I search further, I have a question: Is this kind of service (both and simultaneous ftp access and network file server) correct for such a device? (RN102)
Yes. And of course you should be able to schedule the FTP backups during times when local access is light.
What speeds are you seeing?
easytherm
Jul 02, 2016Aspirant
Hi StephenB and thank you for your response.
I upgraded my NAS to raid (using now 2 HDD)
when I do a backup from an external USB drive connected to my laptop, using Syncbackpro, the speed seemsto be slightly above 5 Mbps. I'm on wifi.
Does this sound correct?
- StephenBJul 02, 2016Guru - Experienced User
What speed are you seeing with speedtest.net?
Also, do you mean 5 megabits per second or 5 megabytes per second?
- easythermJul 02, 2016Aspirant
Hi,
I'm connected locally to the NAS (which is at my home)
when connecting to my NAS over Wifi, I get about 5 megabytes/s, when a connect with cable ethernet, the speed rises to slightly less than 10 megabytes/sec
using speedtest i see an internet download speed of 27 megabytes/s and upload speed of about 6.5 megabytes/s
I have another question ;-), but let's close this case first. Do you think the above speeds are correct for this device?
speedtest.net measures megabits per second, not megabytes per second.
The RN204 can deliver ~90 megabytes per second.
Based on your measurements, I think you are running 802.11n wifi and 100 mbit ethernet.
You can improve wifi and ethernet speeds by upgrading to an 802.11ac gigabit router. Though that depends on the wifi card in your PC.
Increasing just the ethernet speed is less expensive - you'd need to get a gigabit switch and connect your devices to the switch (and the switch to the router).
