easytherm
Jun 25, 2016Aspirant
using a NAS RN102 both as a DDNS ftp server and a local network drive. Is that possible?
Hello everybody I installed about 2 years ago a RN102 NAS at my home in order to have a couple of my websites (remotely hosted) send a daily backup to my NAS. I managed to enable ftp access with...
- Jul 02, 2016
Thanks a lot,
I'll definitely will transit over a gigabit ethernet switch.
I'll ask my other questions over another thread
Jul 02, 2016Guru - Experienced User
speedtest.net measures megabits per second, not megabytes per second.
The RN204 can deliver ~90 megabytes per second.
Based on your measurements, I think you are running 802.11n wifi and 100 mbit ethernet.
You can improve wifi and ethernet speeds by upgrading to an 802.11ac gigabit router. Though that depends on the wifi card in your PC.
Increasing just the ethernet speed is less expensive - you'd need to get a gigabit switch and connect your devices to the switch (and the switch to the router).
easytherm
Jul 02, 2016Aspirant
Thanks a lot,
