Bjohn1
Aug 14, 2020Aspirant
Using a solid state in RN21400
Hi Folks, I have a RN21400 with 2, 2tb HDDs. One of the disks is getting a high uncorrectable error count, so needs replacing. May I replace it with a solid state drive, are these compatible...
- Aug 14, 2020
May I replace it with a solid state drive, are these compatible?
If the size matches, then you can use it. But you won't get SSD speed unless you replace both drives. Likely you will get a warning about a speed mismatch.
FWIW, the HCL only lists Samsung 850 Pro and Samsung 860 Pro models in this size range. The 860 pro is expensive, I don't think the 850 pro is still available in this particular size. Other SSDs likely will work, but at least some of them misbehave in minor ways. For instance: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/rn-expand-2065-Failed-to-get-device-type-for-dev-md0-25/m-p/1941953
Aug 14, 2020Guru - Experienced User
