Robert-M
Feb 20, 2020Aspirant
Using disks not on the HCL?
I've got a ReadyNas NV+ V2, it's running RAIDiator 5.3.13. Appreciate this is a bit long in the tooth nowadays but it's still working well. So far I've only been using disks on the NetGear Hardwa...
Feb 20, 2020Guru - Experienced User
The HCL for your NAS hasn't been updated for years, so it is no longer useful.
I don't recommend using desktop drives (including the DMs you ask about). Instead, I suggest going with NAS purposed drives ( for instance Ironwolf or WD Reds) or enterprise class drives (for instance Ironwolf Pro or WDC Red Pro).
- Robert-MFeb 27, 2020Aspirant
Thanks StephenB, looking at your reply and a few others of the forum it seems that, by and large, newer versions of disks should work (subject to them not exceeding the size constraints) and that the reccomendation is to use NAS specific drives rather than regular ones.
Guess I'll do a test!
- StephenBFeb 27, 2020Guru - Experienced User
Yes. Though of course enterprise-class drives are also fine - but they are overkill for your older NAS (which is limited by its CPU and memory, not the speed of the disks).
