Robert-M
Feb 20, 2020Aspirant
Using disks not on the HCL?
I've got a ReadyNas NV+ V2, it's running RAIDiator 5.3.13. Appreciate this is a bit long in the tooth nowadays but it's still working well. So far I've only been using disks on the NetGear Hardwa...
Robert-M
Feb 27, 2020Aspirant
Thanks StephenB, looking at your reply and a few others of the forum it seems that, by and large, newer versions of disks should work (subject to them not exceeding the size constraints) and that the reccomendation is to use NAS specific drives rather than regular ones.
Guess I'll do a test!
Feb 27, 2020Guru - Experienced User
Yes. Though of course enterprise-class drives are also fine - but they are overkill for your older NAS (which is limited by its CPU and memory, not the speed of the disks).
