rit1
Jun 10, 2014Aspirant
Very disappointed with backup feature of 6.X
I've owned a 104 device for a while now and have just installed a 314 device at a customer. Once the customer was up and running I started the process of deploying a simple backup solution - after...
TonV
I'm also rather disappointed that there is no option to load an SSH key to easily enable Rsync over SSH between two ReadyNAS devices.
Support told me that it is on the 'to do' list for a future release...
I had done some initial tests with Netgear Replicate, to backup from my RN104 to a remote RN102 and thought that is was not working well, however, after changing the default job names to names without "[" and"]" characters in it, it all works fine now, very easy to set up, and it delivers exactly what I was looking for!
It only misses the feature to exclude files, that is okay with me however...
So I'm not sure if Replicate would be an option for you, but you may want to give it a try. Just remember to change the name of the job into something that is Windows friendly :-)
