rit1
Jun 10, 2014Aspirant
Very disappointed with backup feature of 6.X
I've owned a 104 device for a while now and have just installed a 314 device at a customer. Once the customer was up and running I started the process of deploying a simple backup solution - after...
rit1
Jun 11, 2014Aspirant
Netgear Replicate is a solution that I plan to spend some time looking at for wide area backups, but
- It does not resolve the issue of being able to make local backups to attached drives.
- It does not resolve the ussie of being able to use a Readynas device as an Rsync SSH based target where a key must be installed.
- All the devices being used must be Netgear devices with the same major OS version.
I also dislike the fact we seem to have a set of very broken backup features built into our devices and NetGear's answer seems to be to create a totally independent tool that only works with its own products.
