rit1
Jun 10, 2014Aspirant
Very disappointed with backup feature of 6.X
I've owned a 104 device for a while now and have just installed a 314 device at a customer. Once the customer was up and running I started the process of deploying a simple backup solution - after...
Jun 11, 2014Guru - Experienced User
This makes no sense to me. Why do you want SSL, if the connection is local, and doesn't even leave the box?
rit wrote: Rsync over SSH, looping back to the same device has the same advantage as just Rsync in terms of being abled to exclude directories, but there is no way to add the keys via the GUI and to do so via TTY means warnings about lossing access to support..... YET another FAIL
