Varlon
Sep 09, 2011Aspirant
Very Needful Features
Cron mangement GUI: - automatic remove or delete old folders and files, - automatic backup system, - etc... More detailed system info in FW(w/o plugins). All logs(as on freenas-0.7.2). Shared fo...
mdgm-ntgr
Sep 09, 2011NETGEAR Employee Retired
You can already do a fair bit of what you want.
Frontview backup jobs can be scheduled.
There has been a recycle bin feature for a long time.
With Frontview backup you can do full (total) and incremental backups. With ReadyNAS Replicate (http://www.readynas.com/replicate) you can do full, incremental and differential backups.
In Frontview backup you can use the exclude option if using Rsync
Rsync compares the source and destination and is good for backup verification.
Replicate creates differential backups with the date of the backup in the name of the folder.
From time to time NetGear hints as to what they are doing shortly in advance (e.g. regarding adding Lion support, iSCSI compatibility with ESXI 5).
