howarddavidp
Feb 17, 2016Tutor
VGA Header for my Pro 6 RNDP6000
Hello, Sorry to necro this thread. At one point I read the thread that tells you which VGA header to buy from Amazon, but it seems all the links don't work, maybe the forums got re-numbered? ...
mdgm-ntgr
Feb 17, 2016NETGEAR Employee Retired
Nice. If you do want to upgrade the RAM or CPU you should make sure you have the latest BIOS on the unit first.
We migrated over to this community from the old ReadyNAS Community. If you can point me to the post with a broken link I can see what I can find for you.
howarddavidp
Feb 18, 2016Tutor
Hello,
Here is the origianl post (I think) that detailed the VGA header, what top buy, how to look up, etc:
http://www.readynas.com/forum/viewtopic.php?p=223230#p223230.
So it was topic # 223230.
Here are some posts that reference the now dead link:
https://community.netgear.com/t5/Using-your-ReadyNAS/Readynas-Pro-stuck-on-boot/td-p/856541/page/2
Thanks,
David
