matthew-m's avatar
matthew-m
VM image for RAIDiator
Does anyone have a guide to run ReadyNAS OS4 (RAIDiator) in a Virtual Machine? (VirtualBox or KVM).
I found https://community.netgear.com/t5/ReadyNAS-Storage-Apps-Current/RAIDiator-x86-4-2-28-VirtualBox-image-notsupported/td-p/838348 but the download link for the VM file is unavailable.
Thank you.
  • Here is a new upload of that: RAIDiator-x86-4.2.28.ova
    Note the VM uses an OS6 kernel so you can't use it to test kernel modules but for testing most other non-hardware specific things in the OS it should be fine.
ProSupport for Business
