sloth61
Apr 22, 2009Aspirant
VMware Support & NO_ROOT_SQUASH
I want to use the ReadyNAS Duo as my datastore for VMware ESX 3.5. Is the ReadyNAS Duo compatible with VMware? And does the Ready NAS support NFS? Also, does it support the NO_ROOT_SQUASH option? ...
dbott67
Apr 23, 2009Guide
Price difference varies depending on the size and number of drives in each unit. Right now, you can get an extra $200 - $300 off select Pro's: viewtopic.php?f=25&t=27737
Duo with 1 x 500 GB @ 329.98 US:
http://www.eaegis.com/items/data-storag ... s/list.htm
NV+ with 2 x 500 GB @ $599.00 US (same CPU & performance specs as the Duo):
http://www.eaegis.com/items/data-storag ... -/list.htm
NVX with 2 x 1 TB @ 1499.00:
Pro Pioneer (diskless) @ $1248.00 less $200 = $1048.00:
http://www.nashq.com/#RNDEP
Pro Business with 3 x 500 GB @ $1699 less $200 = $1499.00
http://www.eaegis.com/items/data-storag ... n/list.htm
