sloth61
Apr 22, 2009Aspirant
VMware Support & NO_ROOT_SQUASH
I want to use the ReadyNAS Duo as my datastore for VMware ESX 3.5. Is the ReadyNAS Duo compatible with VMware? And does the Ready NAS support NFS? Also, does it support the NO_ROOT_SQUASH option? ...
sloth61
Apr 23, 2009Aspirant
Chirpa, you wrote this:
The ReadyNAS supports NFS with no_root_squash, viewtopic.php?p=143506#p143506
When I go to that topic I see the questiuon is referrinbg toi the ReadyNas NV+. Does this also apply to the Duo? I want to confirm before I buy it. Thanks.
