sloth61
Apr 22, 2009Aspirant
VMware Support & NO_ROOT_SQUASH
I want to use the ReadyNAS Duo as my datastore for VMware ESX 3.5. Is the ReadyNAS Duo compatible with VMware? And does the Ready NAS support NFS? Also, does it support the NO_ROOT_SQUASH option? ...
chirpa
Apr 23, 2009Luminary
NV+ and Duo share the same code base. Main difference is 2-bay and 4-bay. You can find a comparison chart of all products here: http://www.readynas.com/?cat=49
