sloth61
Apr 22, 2009Aspirant
VMware Support & NO_ROOT_SQUASH
I want to use the ReadyNAS Duo as my datastore for VMware ESX 3.5. Is the ReadyNAS Duo compatible with VMware? And does the Ready NAS support NFS? Also, does it support the NO_ROOT_SQUASH option? ...
yoh-dah
May 06, 2009Guide
sloth61 wrote: But I was unable to create a new share and select the NFS protocol. Why is that??? I would like to be able to do that in case I need to create more NFS shares in the future. Thanks in advance for your help.
NFS service is not enabled by default for new shares. You'll need to manually enable it by clicking on the icon in the NFS column on the Share List page and set up default access.
