kenneth84's avatar
kenneth84
Volume dead after disk replacement
So I got a message I had a faulty disk, so i replaced the disk.
The new disk start syncing and finished (Volume: Volume data is resynced.).
a few moments later i get the message the disk 1 is offline and 3 goes from online to resync (see screenshots).
After a reboot all the disk seem to work ok but my volume is gone.
Is there a way to try and restore the volume, in older post there is mentioned to be able to get payed support but i don't get the option to activate it for my NAS if i try to purchase a contract i get the message no contracts available
added screenshots of the logs and the paid support issue
    • Marc_V's avatar
      Marc_V
      NETGEAR Employee Retired
      kenneth84
      Welcome to the Community!
      Were you able to download the logs? It would be best to contact Support since you got your volume inactive but we need to make sure your drives are all healthy by checking the logs or by doing a disk check.
      You may want to try contacting them via Phone as well. I will PM you the number
      HTH
      • kenneth84's avatar
        kenneth84
        Marc_V
        Yes I have the logs,
        I've put them here
        <redacted>
        So do i best to contact support through phone strait away or do want to look at the logs yourself?
ProSupport for Business
