gpaolo
Oct 01, 2020Luminary
Volume: The volume XXXX encountered an error and was made read-only. It is recommended to backup
Hello, I have just received this notification: Volume: The volume Volume1TB encountered an error and was made read-only. It is recommended to backup your data I just checked and the volume is mark...
- Oct 02, 2020
Well, end of the story. For posterity:
when it happens, do not attempt anything except a backup copy.
Files should be ok (they were all fine in my case, no data loss), as someone else said in another similar thread office files won't open, but I think it's because office tries to lock them and it is not able to write on the share, but if you copy them somewhere else they will be ok.
But don't do anything else, after I tried to reboot the volume was completely gone, together with the data.
If this failure happens in the volume including the first disk, applications are lost too. Lesson learned here (it took a while): backup all configurations in a share, which is backed up again.
My two 6-months new WD HDD are now moved to external USB units for automatic backup and two new Seagate Ironwolf disks are in.
Rebuilding is in progress (my personal discovery, copy files from backup USB unit to volumes is a lot faster if done from SSH), let's hope it will last for a while...
Thanks again to StephenB for the support!
gpaolo
ahh, here it is, in kernel.log:
-- Logs begin at Tue 2020-09-01 05:50:10 GMT, end at Thu 2020-10-01 07:03:00 GMT. -- Sep 02 01:00:01 NAS4-CASA-GP kernel: md: requested-resync of RAID array md127 Sep 02 01:00:01 NAS4-CASA-GP kernel: md: minimum _guaranteed_ speed: 30000 KB/sec/disk. Sep 02 01:00:01 NAS4-CASA-GP kernel: md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for requested-resync. Sep 02 01:00:01 NAS4-CASA-GP kernel: md: using 128k window, over a total of 3902168832k. Sep 02 15:08:19 NAS4-CASA-GP kernel: md: md127: requested-resync done. Sep 22 01:00:10 NAS4-CASA-GP kernel: BTRFS info (device md127): relocating block group 3484992667648 flags data Sep 22 01:00:13 NAS4-CASA-GP kernel: BTRFS info (device md127): found 5 extents Sep 22 01:00:22 NAS4-CASA-GP kernel: BTRFS info (device md127): found 5 extents Sep 22 01:00:22 NAS4-CASA-GP kernel: BTRFS info (device md127): relocating block group 3474758565888 flags metadata|dup Sep 22 01:00:31 NAS4-CASA-GP kernel: BTRFS info (device md127): found 254 extents Sep 22 01:00:31 NAS4-CASA-GP kernel: BTRFS info (device md127): relocating block group 3443586498560 flags system|dup Sep 22 01:00:32 NAS4-CASA-GP kernel: BTRFS info (device md127): found 10 extents Sep 22 01:00:32 NAS4-CASA-GP kernel: BTRFS info (device md127): relocating block group 1259528519680 flags data Sep 22 01:00:42 NAS4-CASA-GP kernel: BTRFS info (device md127): found 161 extents Sep 22 01:00:47 NAS4-CASA-GP kernel: BTRFS info (device md127): found 161 extents Sep 22 01:00:48 NAS4-CASA-GP kernel: BTRFS info (device md127): relocating block group 1243422392320 flags data Sep 22 01:00:56 NAS4-CASA-GP kernel: BTRFS info (device md127): found 137 extents Sep 22 01:01:00 NAS4-CASA-GP kernel: BTRFS info (device md127): found 137 extents Oct 01 01:00:08 NAS4-CASA-GP kernel: BTRFS info (device md126): relocating block group 1620943306752 flags data Oct 01 01:00:09 NAS4-CASA-GP kernel: BTRFS info (device md126): found 186 extents Oct 01 01:00:14 NAS4-CASA-GP kernel: BTRFS info (device md126): found 186 extents Oct 01 01:00:15 NAS4-CASA-GP kernel: BTRFS info (device md126): relocating block group 1619869564928 flags data Oct 01 01:00:18 NAS4-CASA-GP kernel: BTRFS info (device md126): found 1107 extents Oct 01 01:00:24 NAS4-CASA-GP kernel: BTRFS info (device md126): found 1107 extents Oct 01 01:00:24 NAS4-CASA-GP kernel: BTRFS info (device md126): relocating block group 1590844981248 flags system|dup Oct 01 01:00:24 NAS4-CASA-GP kernel: BTRFS info (device md126): found 6 extents Oct 01 01:09:06 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:09:06 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:09:06 NAS4-CASA-GP kernel: BTRFS: error (device md126) in btrfs_update_root:148: errno=-5 IO failure Oct 01 01:09:06 NAS4-CASA-GP kernel: BTRFS info (device md126): forced readonly Oct 01 01:09:06 NAS4-CASA-GP kernel: BTRFS warning (device md126): Skipping commit of aborted transaction. Oct 01 01:09:06 NAS4-CASA-GP kernel: BTRFS: error (device md126) in cleanup_transaction:1864: errno=-5 IO failure Oct 01 01:09:06 NAS4-CASA-GP kernel: BTRFS info (device md126): delayed_refs has NO entry Oct 01 01:14:11 NAS4-CASA-GP kernel: BTRFS error (device md126): Remounting read-write after error is not allowed Oct 01 01:14:11 NAS4-CASA-GP kernel: BTRFS error (device md126): Remounting read-write after error is not allowed Oct 01 01:14:11 NAS4-CASA-GP kernel: BTRFS error (device md126): Remounting read-write after error is not allowed Oct 01 01:14:11 NAS4-CASA-GP kernel: BTRFS error (device md126): Remounting read-write after error is not allowed Oct 01 01:14:13 NAS4-CASA-GP kernel: BTRFS error (device md126): Remounting read-write after error is not allowed Oct 01 01:14:13 NAS4-CASA-GP kernel: BTRFS error (device md126): Remounting read-write after error is not allowed Oct 01 01:14:13 NAS4-CASA-GP kernel: BTRFS error (device md126): Remounting read-write after error is not allowed Oct 01 01:14:13 NAS4-CASA-GP kernel: BTRFS error (device md126): Remounting read-write after error is not allowed Oct 01 01:14:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:14:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:15:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:15:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:16:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:16:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:17:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:17:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:18:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:18:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:19:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:19:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:20:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:20:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:21:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:21:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:22:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:22:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:23:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120 Oct 01 01:23:19 NAS4-CASA-GP kernel: BTRFS critical (device md126): corrupt leaf, bad key order: block=730591854592, root=1, slot=120
gpaolo
I am trying to understand which one of the two disks might have some problem. Following the indication in another thread ( https://community.netgear.com/t5/New-ReadyNAS-Users-General/Rn314-update-to-6-10-1-made-volume-to-read-only/m-p/1758058#M36868 ) I have tried
# smartctl -x /dev/sda
Results for the two disks in the volume are attached. I can´t see any error in there ---I have to split the message, can't attach txt and can't copy paste it all...
root@NAS4-CASA-GP:~# smartctl -x /dev/sda
smartctl 6.6 2017-11-05 r4594 [x86_64-linux-4.4.190.x86_64.1] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Red
Device Model: WDC WD40EFRX-68N32N0
Serial Number: WD-WCC7K1YJCZ2P
LU WWN Device Id: 5 0014ee 211d8150b
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Thu Oct 1 09:31:41 2020 GMT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 247) Self-test routine in progress...
70% of test remaining.
Total time to complete Offline
data collection: (43380) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 461) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0
3 Spin_Up_Time POS--K 188 162 021 - 5566
4 Start_Stop_Count -O--CK 077 077 000 - 23781
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 200 200 000 - 0
9 Power_On_Hours -O--CK 095 095 000 - 3855
10 Spin_Retry_Count -O--CK 100 100 000 - 0
11 Calibration_Retry_Count -O--CK 100 253 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 1
192 Power-Off_Retract_Count -O--CK 200 200 000 - 0
193 Load_Cycle_Count -O--CK 193 193 000 - 23781
194 Temperature_Celsius -O---K 121 107 000 - 29
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 0
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 100 253 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb6 GPL,SL VS 1 Device vendor specific log
0xb7 GPL,SL VS 56 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 93 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
SCT Support Level: 1
Device State: DST executing in background (3)
Current Temperature: 29 Celsius
Power Cycle Min/Max Temperature: 20/43 Celsius
Lifetime Min/Max Temperature: 20/43 Celsius
Under/Over Temperature Limit Count: 0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/65 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 478 (182)
Index Estimated Time Temperature Celsius
183 2020-10-01 01:34 21 **
... ..( 14 skipped). .. **
198 2020-10-01 01:49 21 **
199 2020-10-01 01:50 20 *
... ..( 25 skipped). .. *
225 2020-10-01 02:16 20 *
226 2020-10-01 02:17 ? -
227 2020-10-01 02:18 20 *
228 2020-10-01 02:19 21 **
... ..( 2 skipped). .. **
231 2020-10-01 02:22 21 **
232 2020-10-01 02:23 22 ***
233 2020-10-01 02:24 22 ***
234 2020-10-01 02:25 22 ***
235 2020-10-01 02:26 23 ****
236 2020-10-01 02:27 ? -
237 2020-10-01 02:28 23 ****
... ..( 2 skipped). .. ****
240 2020-10-01 02:31 23 ****
241 2020-10-01 02:32 24 *****
242 2020-10-01 02:33 24 *****
243 2020-10-01 02:34 ? -
244 2020-10-01 02:35 25 ******
... ..( 2 skipped). .. ******
247 2020-10-01 02:38 25 ******
248 2020-10-01 02:39 26 *******
... ..( 2 skipped). .. *******
251 2020-10-01 02:42 26 *******
252 2020-10-01 02:43 27 ********
253 2020-10-01 02:44 27 ********
254 2020-10-01 02:45 27 ********
255 2020-10-01 02:46 28 *********
... ..( 15 skipped). .. *********
271 2020-10-01 03:02 28 *********
272 2020-10-01 03:03 29 **********
... ..( 65 skipped). .. **********
338 2020-10-01 04:09 29 **********
339 2020-10-01 04:10 28 *********
... ..( 9 skipped). .. *********
349 2020-10-01 04:20 28 *********
350 2020-10-01 04:21 29 **********
351 2020-10-01 04:22 28 *********
... ..( 10 skipped). .. *********
362 2020-10-01 04:33 28 *********
363 2020-10-01 04:34 29 **********
... ..( 18 skipped). .. **********
382 2020-10-01 04:53 29 **********
383 2020-10-01 04:54 26 *******
384 2020-10-01 04:55 26 *******
385 2020-10-01 04:56 26 *******
386 2020-10-01 04:57 25 ******
... ..( 5 skipped). .. ******
392 2020-10-01 05:03 25 ******
393 2020-10-01 05:04 24 *****
394 2020-10-01 05:05 24 *****
395 2020-10-01 05:06 ? -
396 2020-10-01 05:07 24 *****
399 2020-10-01 05:10 24 *****
400 2020-10-01 05:11 25 ******
... ..( 7 skipped). .. ******
408 2020-10-01 05:19 25 ******
409 2020-10-01 05:20 ? -
410 2020-10-01 05:21 25 ******
... ..( 4 skipped). .. ******
415 2020-10-01 05:26 25 ******
416 2020-10-01 05:27 26 *******
... ..( 4 skipped). .. *******
421 2020-10-01 05:32 26 *******
422 2020-10-01 05:33 25 ******
428 2020-10-01 05:39 25 ******
429 2020-10-01 05:40 ? -
430 2020-10-01 05:41 24 *****
433 2020-10-01 05:44 24 *****
434 2020-10-01 05:45 25 ******
442 2020-10-01 05:53 25 ******
443 2020-10-01 05:54 24 *****
... ..( 6 skipped). .. *****
450 2020-10-01 06:01 24 *****
451 2020-10-01 06:02 ? -
452 2020-10-01 06:03 24 *****
458 2020-10-01 06:09 24 *****
459 2020-10-01 06:10 25 ******
464 2020-10-01 06:15 25 ******
465 2020-10-01 06:16 ? -
466 2020-10-01 06:17 25 ******
472 2020-10-01 06:23 25 ******
473 2020-10-01 06:24 26 *******
0 2020-10-01 06:29 26 *******
1 2020-10-01 06:30 27 ********
12 2020-10-01 06:41 27 ********
13 2020-10-01 06:42 26 *******
18 2020-10-01 06:47 26 *******
19 2020-10-01 06:48 25 ******
24 2020-10-01 06:53 25 ******
25 2020-10-01 06:54 24 *****
33 2020-10-01 07:02 24 *****
34 2020-10-01 07:03 23 ****
44 2020-10-01 07:13 23 ****
45 2020-10-01 07:14 22 ***
... ..( 23 skipped). .. ***
69 2020-10-01 07:38 22 ***
70 2020-10-01 07:39 21 **
... ..( 51 skipped). .. **
122 2020-10-01 08:31 21 **
123 2020-10-01 08:32 ? -
124 2020-10-01 08:33 21 **
129 2020-10-01 08:38 21 **
130 2020-10-01 08:39 22 ***
... ..( 25 skipped). .. ***
156 2020-10-01 09:05 22 ***
157 2020-10-01 09:06 21 **
... ..( 24 skipped). .. **
182 2020-10-01 09:31 21 **
SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 1) ==
0x01 0x008 4 1 --- Lifetime Power-On Resets
0x01 0x010 4 3855 --- Power-on Hours
0x01 0x018 6 10632268361 --- Logical Sectors Written
0x01 0x020 6 64491989 --- Number of Write Commands
0x01 0x028 6 324623431 --- Logical Sectors Read
0x01 0x030 6 687054 --- Number of Read Commands
0x01 0x038 6 993098112 --- Date and Time TimeStamp
0x03 ===== = = === == Rotating Media Statistics (rev 1) ==
0x03 0x008 4 2286 --- Spindle Motor Power-on Hours
0x03 0x010 4 2241 --- Head Flying Hours
0x03 0x018 4 23781 --- Head Load Events
0x03 0x020 4 0 --- Number of Reallocated Logical Sectors
0x03 0x028 4 0 --- Read Recovery Attempts
0x03 0x030 4 0 --- Number of Mechanical Start Failures
0x03 0x038 4 0 --- Number of Realloc. Candidate Logical Sectors
0x03 0x040 4 0 --- Number of High Priority Unload Events
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 29 --- Current Temperature
0x05 0x010 1 26 --- Average Short Term Temperature
0x05 0x018 1 28 --- Average Long Term Temperature
0x05 0x020 1 43 --- Highest Temperature
0x05 0x028 1 20 --- Lowest Temperature
0x05 0x030 1 39 --- Highest Average Short Term Temperature
0x05 0x038 1 23 --- Lowest Average Short Term Temperature
0x05 0x040 1 32 --- Highest Average Long Term Temperature
0x05 0x048 1 28 --- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 65 --- Specified Maximum Operating Temperature
0x05 0x060 4 0 --- Time in Under-Temperature
0x05 0x068 1 0 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 1 --- Number of Hardware Resets
0x06 0x010 4 0 --- Number of ASR Events
0x06 0x018 4 0 --- Number of Interface CRC Errors
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 0 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 1 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000d 2 0 Non-CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 13879345 Vendor specific
- gpaoloOct 01, 2020Luminary
root@NAS4-CASA-GP:~# smartctl -x /dev/sdf smartctl 6.6 2017-11-05 r4594 [x86_64-linux-4.4.190.x86_64.1] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: WDC WD40EFAX-68JH4N0 Serial Number: WD-WX42D10FCJ36 LU WWN Device Id: 5 0014ee 267aef87e Firmware Version: 82.00A82 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Thu Oct 1 09:38:40 2020 GMT SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM feature is: Unavailable Rd look-ahead is: Enabled Write cache is: Enabled DSN feature is: Unavailable ATA Security is: Disabled, NOT FROZEN [SEC1] Wt Cache Reorder: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 241) Self-test routine in progress... 10% of test remaining. Total time to complete Offline data collection: ( 3764) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 146) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x3039) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0 3 Spin_Up_Time POS--K 207 206 021 - 2633 4 Start_Stop_Count -O--CK 073 073 000 - 27749 5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0 7 Seek_Error_Rate -OSR-K 200 200 000 - 0 9 Power_On_Hours -O--CK 095 095 000 - 3859 10 Spin_Retry_Count -O--CK 100 100 000 - 0 11 Calibration_Retry_Count -O--CK 100 253 000 - 0 12 Power_Cycle_Count -O--CK 100 100 000 - 1 192 Power-Off_Retract_Count -O--CK 200 200 000 - 0 193 Load_Cycle_Count -O--CK 191 191 000 - 27749 194 Temperature_Celsius -O---K 121 104 000 - 26 196 Reallocated_Event_Count -O--CK 200 200 000 - 0 197 Current_Pending_Sector -O--CK 200 200 000 - 0 198 Offline_Uncorrectable ----CK 100 253 000 - 0 199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0 200 Multi_Zone_Error_Rate ---R-- 100 253 000 - 0 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 5 Comprehensive SMART error log 0x03 GPL R/O 6 Ext. Comprehensive SMART error log 0x04 GPL R/O 256 Device Statistics log 0x04 SL R/O 8 Device Statistics log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 1 Extended self-test log 0x09 SL R/W 1 Selective self-test log 0x0c GPL R/O 2048 Pending Defects log 0x10 GPL R/O 1 NCQ Command Error log 0x11 GPL R/O 1 SATA Phy Event Counters log 0x24 GPL R/O 294 Current Device Internal Status Data log 0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xa0-0xa7 GPL,SL VS 16 Device vendor specific log 0xa8-0xb6 GPL,SL VS 1 Device vendor specific log 0xb7 GPL,SL VS 78 Device vendor specific log 0xb9 GPL,SL VS 4 Device vendor specific log 0xbd GPL,SL VS 1 Device vendor specific log 0xc0 GPL,SL VS 1 Device vendor specific log 0xc1 GPL VS 93 Device vendor specific log 0xe0 GPL,SL R/W 1 SCT Command/Status 0xe1 GPL,SL R/W 1 SCT Data Transfer SMART Extended Comprehensive Error Log Version: 1 (6 sectors) No Errors Logged SMART Extended Self-test Log Version: 1 (1 sectors) No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. SCT Status Version: 3 SCT Version (vendor specific): 258 (0x0102) SCT Support Level: 1 Device State: DST executing in background (3) Current Temperature: 26 Celsius Power Cycle Min/Max Temperature: 20/43 Celsius Lifetime Min/Max Temperature: 20/43 Celsius Under/Over Temperature Limit Count: 0/0 Vendor specific: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 SCT Temperature History Version: 2 Temperature Sampling Period: 1 minute Temperature Logging Interval: 1 minute Min/Max recommended Temperature: 0/65 Celsius Min/Max Temperature Limit: -41/85 Celsius Temperature History Size (Index): 478 (7) Index Estimated Time Temperature Celsius 8 2020-10-01 01:41 21 ** 9 2020-10-01 01:42 20 * ... ..( 17 skipped). .. * 27 2020-10-01 02:00 20 * 28 2020-10-01 02:01 ? - 29 2020-10-01 02:02 20 * 30 2020-10-01 02:03 20 * 31 2020-10-01 02:04 20 * 32 2020-10-01 02:05 21 ** 33 2020-10-01 02:06 21 ** 34 2020-10-01 02:07 21 ** 35 2020-10-01 02:08 22 *** 36 2020-10-01 02:09 22 *** 37 2020-10-01 02:10 ? - 38 2020-10-01 02:11 22 *** ... ..( 4 skipped). .. *** 43 2020-10-01 02:16 22 *** 44 2020-10-01 02:17 23 **** ... ..( 2 skipped). .. **** 47 2020-10-01 02:20 23 **** 48 2020-10-01 02:21 ? - 49 2020-10-01 02:22 23 **** 50 2020-10-01 02:23 22 *** 51 2020-10-01 02:24 22 *** 52 2020-10-01 02:25 22 *** 53 2020-10-01 02:26 23 **** ... ..( 2 skipped). .. **** 56 2020-10-01 02:29 23 **** 57 2020-10-01 02:30 24 ***** ... ..( 4 skipped). .. ***** 62 2020-10-01 02:35 24 ***** 63 2020-10-01 02:36 25 ****** ... ..( 5 skipped). .. ****** 69 2020-10-01 02:42 25 ****** 70 2020-10-01 02:43 26 ******* ... ..( 62 skipped). .. ******* 133 2020-10-01 03:46 26 ******* 134 2020-10-01 03:47 25 ****** 135 2020-10-01 03:48 26 ******* 136 2020-10-01 03:49 25 ****** ... ..( 62 skipped). .. ****** 199 2020-10-01 04:52 25 ****** 200 2020-10-01 04:53 26 ******* 201 2020-10-01 04:54 25 ****** ... ..( 4 skipped). .. ****** 206 2020-10-01 04:59 25 ****** 207 2020-10-01 05:00 26 ******* 208 2020-10-01 05:01 ? - 209 2020-10-01 05:02 24 ***** ... ..( 5 skipped). .. ***** 215 2020-10-01 05:08 24 ***** 216 2020-10-01 05:09 25 ****** ... ..( 2 skipped). .. ****** 219 2020-10-01 05:12 25 ****** 220 2020-10-01 05:13 26 ******* 221 2020-10-01 05:14 26 ******* 222 2020-10-01 05:15 25 ****** 223 2020-10-01 05:16 25 ****** 224 2020-10-01 05:17 25 ****** 225 2020-10-01 05:18 ? - 226 2020-10-01 05:19 25 ****** ... ..( 7 skipped). .. ****** 234 2020-10-01 05:27 25 ****** 235 2020-10-01 05:28 26 ******* ... ..( 3 skipped). .. ******* 239 2020-10-01 05:32 26 ******* 240 2020-10-01 05:33 25 ****** ... ..( 3 skipped). .. ****** 244 2020-10-01 05:37 25 ****** 245 2020-10-01 05:38 ? - 246 2020-10-01 05:39 25 ****** 247 2020-10-01 05:40 24 ***** ... ..( 2 skipped). .. ***** 250 2020-10-01 05:43 24 ***** 251 2020-10-01 05:44 25 ****** ... ..( 3 skipped). .. ****** 255 2020-10-01 05:48 25 ****** 256 2020-10-01 05:49 ? - 257 2020-10-01 05:50 25 ****** 258 2020-10-01 05:51 24 ***** 259 2020-10-01 05:52 24 ***** 260 2020-10-01 05:53 24 ***** 261 2020-10-01 05:54 25 ****** ... ..( 4 skipped). .. ****** 266 2020-10-01 05:59 25 ****** 267 2020-10-01 06:00 24 ***** 268 2020-10-01 06:01 24 ***** 269 2020-10-01 06:02 ? - 270 2020-10-01 06:03 24 ***** ... ..( 5 skipped). .. ***** 276 2020-10-01 06:09 24 ***** 277 2020-10-01 06:10 25 ****** ... ..( 6 skipped). .. ****** 284 2020-10-01 06:17 25 ****** 285 2020-10-01 06:18 26 ******* ... ..( 11 skipped). .. ******* 297 2020-10-01 06:30 26 ******* 298 2020-10-01 06:31 27 ******** ... ..( 8 skipped). .. ******** 307 2020-10-01 06:40 27 ******** 308 2020-10-01 06:41 26 ******* ... ..( 2 skipped). .. ******* 311 2020-10-01 06:44 26 ******* 312 2020-10-01 06:45 25 ****** ... ..( 2 skipped). .. ****** 315 2020-10-01 06:48 25 ****** 316 2020-10-01 06:49 24 ***** ... ..( 4 skipped). .. ***** 321 2020-10-01 06:54 24 ***** 322 2020-10-01 06:55 23 **** ... ..( 5 skipped). .. **** 328 2020-10-01 07:01 23 **** 329 2020-10-01 07:02 22 *** 330 2020-10-01 07:03 23 **** 331 2020-10-01 07:04 22 *** ... ..( 5 skipped). .. *** 337 2020-10-01 07:10 22 *** 338 2020-10-01 07:11 ? - 339 2020-10-01 07:12 22 *** ... ..( 3 skipped). .. *** 343 2020-10-01 07:16 22 *** 344 2020-10-01 07:17 23 **** ... ..( 4 skipped). .. **** 349 2020-10-01 07:22 23 **** 350 2020-10-01 07:23 22 *** ... ..( 11 skipped). .. *** 362 2020-10-01 07:35 22 *** 363 2020-10-01 07:36 21 ** ... ..( 50 skipped). .. ** 414 2020-10-01 08:27 21 ** 415 2020-10-01 08:28 20 * 416 2020-10-01 08:29 21 ** 417 2020-10-01 08:30 21 ** 418 2020-10-01 08:31 21 ** 419 2020-10-01 08:32 ? - 420 2020-10-01 08:33 21 ** 421 2020-10-01 08:34 20 * 422 2020-10-01 08:35 20 * 423 2020-10-01 08:36 21 ** 424 2020-10-01 08:37 21 ** 425 2020-10-01 08:38 22 *** ... ..( 2 skipped). .. *** 428 2020-10-01 08:41 22 *** 429 2020-10-01 08:42 23 **** ... ..( 7 skipped). .. **** 437 2020-10-01 08:50 23 **** 438 2020-10-01 08:51 22 *** ... ..( 9 skipped). .. *** 448 2020-10-01 09:01 22 *** 449 2020-10-01 09:02 21 ** ... ..( 32 skipped). .. ** 4 2020-10-01 09:35 21 ** 5 2020-10-01 09:36 20 * 6 2020-10-01 09:37 20 * 7 2020-10-01 09:38 20 * SCT Error Recovery Control: Read: 70 (7.0 seconds) Write: 70 (7.0 seconds) Device Statistics (GP/SMART Log 0x04) not supported Pending Defects log (GP Log 0x0c) supported [please try: '-l defects'] SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x0001 2 0 Command failed due to ICRC error 0x0002 2 0 R_ERR response for data FIS 0x0003 2 0 R_ERR response for device-to-host data FIS 0x0004 2 0 R_ERR response for host-to-device data FIS 0x0005 2 0 R_ERR response for non-data FIS 0x0006 2 0 R_ERR response for device-to-host non-data FIS 0x0007 2 0 R_ERR response for host-to-device non-data FIS 0x0008 2 0 Device-to-host non-data FIS retries 0x0009 2 0 Transition from drive PhyRdy to drive PhyNRdy 0x000a 2 1 Device-to-host register FISes sent due to a COMRESET 0x000b 2 0 CRC errors within host-to-device FIS 0x000d 2 0 Non-CRC errors within host-to-device FIS 0x000f 2 0 R_ERR response for host-to-device data FIS, CRC 0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC 0x8000 4 13892822 Vendor specific root@NAS4-CASA-GP:~#- StephenBOct 01, 2020Guru - Experienced User
The WD40EFAX might be part of the equation. It uses SMR technology (which WD finally admitted last April), SMR drives slow down significantly during sustained writes, so they aren't great for RAID arrays. https://www.servethehome.com/wd-red-smr-vs-cmr-tested-avoid-red-smr/2/ Personally I would replace it. You could reach out to WD, not sure if they would exchange it for a WD40EFRX or not. Given the controversy, and the fact that you are having some problems with your array, they might be open to that.
This of course is the error. There is a disk test function on the volume tab that you might want to run. But it is possible that the IO failure was a timeout of some kind (because of the major write slowdown SMRs can suffer from).
While it is likely possible that you could recover the volume with ssh, the best approach is to rebuild the array with s factory reset. If you are skilled with ssh, we can provide you with some steps to recover the array.
BTW, it isn't a great idea to post the log zip file publicly, as there is some leakage of private information. I've taken the liberty of redacting your download link.
Thank you Stephen, you are very helpful as usual.
I became aware of the EFAX story too late to send back the drive, but I might try to contact WD as you suggest.
Actually, since the drives are new, I was thinking of moving them to a USB unit and use them for backup of the NAS, and get two new drives...
I have the disk test in progress, do you know if, in case it is successful, will unlock the volume?
Thanks also for the link of the log packet, you are right.
