Waldothere
Feb 14, 2019Tutor
Wake On Lan becomes inop withj 6.9.5 update
2 3TB WD drives in a ReadyNAS RN102, wake-On-LAN worked fine before updating with 6.9.5.
Is it Ok to go back to 6.9.4 or will a fix be available shortly?
Feb 15, 2019Guru - Experienced User
I'm running 6.9.5, and my RN102 responded normally to WoL yesterday.
You might try downgrading, and if 6.9.4 resolves it, then try upgrading again.
- WaldothereFeb 15, 2019Tutor
Ok, Thanks I'll work on it.
