Waldothere
Feb 14, 2019Tutor
Wake On Lan becomes inop withj 6.9.5 update
2 3TB WD drives in a ReadyNAS RN102, wake-On-LAN worked fine before updating with 6.9.5.
Is it Ok to go back to 6.9.4 or will a fix be available shortly?
Feb 15, 2019Guru - Experienced User
I'm running 6.9.5, and my RN102 responded normally to WoL yesterday.
You might try downgrading, and if 6.9.4 resolves it, then try upgrading again.
Waldothere
Feb 15, 2019Tutor
Ok, Thanks I'll work on it.
