llevet
Nov 01, 2005Aspirant
Wake up ReadyNas by network ?
Hi, It will bee cool to have the possibility to wake up the ReadyNas by the network (with magical packet like 'ether-wake MAC ADDR' under linux). So, it is maybe not possible, because when the r...
c3po
Jan 18, 2007NETGEAR Expert
nils_heidorn wrote: Hi !
could you give a hint where the power switch pin is, or is it easy to find if i open it up and look for it ?
Thanks for helping !!!!!!
Nils
For Rev B ReadyNAS 600/X6, Power switch pin is pin 7 of J23(Located
at left front corner, please note how pin is numbered, pin 6 is keyed.
Pin 7 is the pin left to "3" of label "J23", Pin 9 is ground, you way want to
use beep to verify) Pin 7 is pulled up by 2.2KOhm to standby 5V, if WOL
pulse temporary(Can not hold it longer than 5 seconds) pull it down,
main power will turn on.
(Connect WOL pulse correctly to Pin 7 and 9, you may need to invert the
pulse depends on polarity of the pulse. Now you are on your own to have
fun and absolutely no warranty :P )
Someone made this :lol: It should work with any ReadyNAS as long as
you know how to hook the WOL cable to power button
http://www.hackaday.com/2006/10/23/wake-on-lan-network-tester
You do not need batteries. All you need to do is bring out 3 wires from
ReadyNAS to NIC's WOL connector(AUX5V, GND, WOL to power switch)
this also solves the problem for those complain NV stays off after power outrage 8)
For more information on WOL connector:
http://www.wimsbios.com/phpBB2/topic8682.html
