llevet
Nov 01, 2005Aspirant
Wake up ReadyNas by network ?
Hi, It will bee cool to have the possibility to wake up the ReadyNas by the network (with magical packet like 'ether-wake MAC ADDR' under linux). So, it is maybe not possible, because when the r...
Keith_Beef
Mar 22, 2009Aspirant
chirpa wrote: The NV+ does not support Wake-on-LAN, hardware limitation.
Boo Hiss
OK, I can live without it, but when just about every x86 architecture board from $50 and up has WOL, I think it's a bit short-sighted to have left it out of the NV+ hardware.
I suppose a workaround would be to use the WOL on the main computer; then when that computer is awake, use it to control the robot arm to pick up a piece of dowel and poke the power switch on the NV+, then power down the computer. ;)
K.
