bkxit
Nov 21, 2019Tutor
Warning Message...
Nov 21, 2019 08:00:18 AM Volume: System volume root's usage is 81%. This condition should not occur under normal conditions. Contact technical support. Hi All. Just had this aler...
- Nov 21, 2019
bkxit wrote:
Do i need to be looking in another dir that possibly has the offending build up of files ?
how would i look at the dir of the sys volume to see whats in there and what size ?
Try the steps here for plex:
While you have the OS partition remounted, you should also look in /mnt/media. Look for files in the USB_HDD* folders there - the ones in /mnt should be empty.
Marc_V
Nov 21, 2019NETGEAR Employee Retired
Welcome to the Community!
That warning message appears when your ReadyNAS System Volume capacity reaches 80% and up. This means that an app installed or logs that uses your System volume is filling up the space and this is not normal since the app or logs should not be using the System volume.
I would suggest contacting Support through my.netgear.com so they can assist you on getting this corrected. You will have to purchase a contract if your 90 days support is expired.
Otherwise, accessing the NAS through SSH and removing the files filling up the space is another resolution. This will need you to be comfortable using it.
HTH
Regards
bkxit
Nov 21, 2019Tutor
Hi Marc.
Many thanks for the quick reply............ Sorry to show a bit of ignorance here,
So the System volume , Thats not the free disc space then ?
I have 1.47tb data and 2.16 Free.
so to my thinking i have enough free disc space ???
I have just cleared the system logs and im running scrug defrag and ballance.
Is the sys volume a specific area of the storage ???
Again thanks for your helpfull reply..
Best Wishes John..
- Marc_VNov 21, 2019NETGEAR Employee Retired
Yes Data volume is different from System root volume.
System is actually 4GB in size. Unfortunately, clearing the system logs and or running volume maintenance may not affect the system volume since it is actually targeting the data volume.
It is really advisable to contact Support for proper assistance or use the Community guide on clearing up System root volume but only if you are comfortable using SSH.
HTH
Regards
- StephenBNov 21, 2019Guru - Experienced User
I agree. If you aren't already familiar with linux commands, you should use support. Ask for per-incident support. Don't purchase the gearhead support - it's not what you want for this.
- bkxitNov 21, 2019Tutor
Hi All.
many thanks for the info.......... Im not too familar with SSH and have looked at the community advice and think you
are possibly correct in getting support help...
So is this a new problem thats occured with a firmware update ?
Ive had my NAS for several years now with no problems before, or is it the fact that its been several years ??
I would have thaught these Temp files would be deleted by the system in order to prevent this becoming a problem
Cheers to All...
