bkxit
Nov 21, 2019Tutor
Warning Message...
Nov 21, 2019 08:00:18 AM Volume: System volume root's usage is 81%. This condition should not occur under normal conditions. Contact technical support. Hi All. Just had this aler...
- Nov 21, 2019
bkxit wrote:
Do i need to be looking in another dir that possibly has the offending build up of files ?
how would i look at the dir of the sys volume to see whats in there and what size ?
Try the steps here for plex:
While you have the OS partition remounted, you should also look in /mnt/media. Look for files in the USB_HDD* folders there - the ones in /mnt should be empty.
bkxit
Nov 21, 2019Tutor
Hi All.
Ok ........Had a quick look via SSH following others instructions ,
Expected to see the temp files in var/lib/clamav is -lah.
But ........... nothing there.
See screenshot attached.
i have plex installed on the NAS .with a large libary
before i call support .
Thanks all..
Nov 21, 2019Guru - Experienced User
- bkxitNov 23, 2019Tutor
Stephen...........
You total HERO !!!!!!! thank you so much for your help it was full fo .m4s files.
sucessfuly deleted, also there were a lot of numbered chunk files ..............i deleted these also.
The sys volume is now down to1.2gb
Do you think these files are created every time you use Plex ?
Or possibly not shutting it down properly ?
It seems impossible to contact Netgear to ask about support....... you just get directed to the support portal and told to purchase Gearhead support package. this seems to be the only option.
Thanks for your patience and help, it was no where near as daunting as i thaught .
best wishes............ john.
