miogpsrocks's avatar
Mar 25, 2018
WD 8TB Easystore " White Label" what type of drive is this?
WD Easystore  " White Label" what type of drive is this?  WDBCKA0080HBK
Are these like mystery drive that no one know exactly what type of drive is behind it or are they a particular type of drive?
This was in one of those external HD from Western digitral.
Thanks.
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi miogpsrocks
    Checking on the drives, they all say it's the same with the WD Reds in anyway. The only issue with the Whites would be the 3.3v issue and alteration on the plug for it to spin up. Read it here.
    You might want to check this discussion from a different forum where they remove the drives to use it on their NAS/FreeNAS. Personally I would not recommend usng an OEM drive that is specifically made for their internal enclosure but of course the price difference is what makes them go for it rather than purchasing the WD Reds.
    Other members might also have experienced using the white drives so waiting for their feed backs is also a good idea.
    Hope this helps!
    Regards
  • Marc_V's avatar
    Marc_V
    Hi miogpsrocks
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
    The Netgear community looks forward to hearing from you and being a helpful resource in the future!
