salttoft
Jul 30, 2012Aspirant
WD Caviar Green 2.5 tb compability?
Dear forum, I tried to search if anyone else have faced the same problem as me with the HDD with type number "WD25EZRX" but it doesn't seem to be the case. This HDD comes from a series where bot...
mdgm-ntgr
Jul 30, 2012NETGEAR Employee Retired
What version of RAIDiator are you running?
Can you confirm you have the v2 by reading this article: How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2
If you have the v1 this would explain the issue as drives larger than 2TB are incompatible with the v1.
