salttoft
Jul 30, 2012Aspirant
WD Caviar Green 2.5 tb compability?
Dear forum, I tried to search if anyone else have faced the same problem as me with the HDD with type number "WD25EZRX" but it doesn't seem to be the case. This HDD comes from a series where bot...
salttoft
Jul 31, 2012Aspirant
Thanks for your help mdgm!
I updated the firmware on the NAS it self but I will need to check what version of RAIDiator (which is the software on the PC right?)
When I look underneath on the serial number sticker it says RND2110v2 but as per the picture from your link the back looks more like the Duo v1. I will need to follow up on that but I would tend to follow the serial number - do you disagree?
Thanks,
Salttoft
Thanks,
Salttoft
