salttoft
Jul 30, 2012Aspirant
WD Caviar Green 2.5 tb compability?
Dear forum, I tried to search if anyone else have faced the same problem as me with the HDD with type number "WD25EZRX" but it doesn't seem to be the case. This HDD comes from a series where bot...
salttoft
Jul 31, 2012Aspirant
Hi again,
I have now checked the ReadyNAS.
It runs on RAIDiator 4.1.9 and it doesn't say v2 in the lower right corner on the front, it only writes ReadyNAS DUO on the Front. On the bottom of the NAS it writes a serial number of RND2110v2 so I assumed it was a v2, but you think it isn't?
So if I have a ReadyNAS DUOv1 will it then work with a 2tb HDD only?
Thanks for your help,
Salttoft
Salttoft
