jbaird
Aug 01, 2013Aspirant
WD Green HD Replacement
I have a ReadyNAS pro with 4x WD Green 1.5 (WD15EAS) disks running XRAID2. One of the disks has failed and is out of warranty. These particular disks are not being made anymore. The closest thing I...
mdgm-ntgr
Aug 01, 2013NETGEAR Employee Retired
Get the 2TB Red. The Red is a much better choice than Green drives for NAS use.
If you want to use a disk with capacity greater than 2TB make sure that the firmware has been updated to 4.2.16 or later before installing the disk.
