jbaird
Aug 01, 2013Aspirant
WD Green HD Replacement
I have a ReadyNAS pro with 4x WD Green 1.5 (WD15EAS) disks running XRAID2. One of the disks has failed and is out of warranty. These particular disks are not being made anymore. The closest thing I...
jbaird
Thanks for the reply. If I eventually replace each 1.5TB green disk with red 2TB disks, I can grow my RAID volume, correct?
