jbaird
Aug 01, 2013Aspirant
WD Green HD Replacement
I have a ReadyNAS pro with 4x WD Green 1.5 (WD15EAS) disks running XRAID2. One of the disks has failed and is out of warranty. These particular disks are not being made anymore. The closest thing I...
mdgm-ntgr
Aug 01, 2013NETGEAR Employee Retired
If two were replaced with 2TB disks your volume would expand assuming you are using single-redundancy. You would need four 2TB disks for vertical expansion if using dual-redundancy.
