Rudy_san
Jul 27, 2012Aspirant
WD Red 2Gb Drive (WD20EFRX) compatibility with NV+ v1
Does anyone know whether the new WD Red 2Gb drive (WD20EFRX) is compatible with the old NV+ v1? I see the 1Gb model (WD10EFRX) and well as the old 2Gb WD2EARX listed in the hardware compatibility l...
mdgm-ntgr
Jul 27, 2012NETGEAR Employee Retired
Last week I asked about the WD Red Series and Sparc. They were planning to test the 2TB drive. So either they haven't tested it yet or it's currently in testing. Hopefully it passes and gets added to the list. The drives are planned to be tested in the Duo v1 as well.
Do note that just because one model in a series is compatible it doesn't mean that the other models are. It may be a good indication that the drive is likely to be compatible, but it's no guarantee. NetGear can and will deny support if you use drives outside the list.
