Rudy_san
Jul 27, 2012Aspirant
WD Red 2Gb Drive (WD20EFRX) compatibility with NV+ v1
Does anyone know whether the new WD Red 2Gb drive (WD20EFRX) is compatible with the old NV+ v1? I see the 1Gb model (WD10EFRX) and well as the old 2Gb WD2EARX listed in the hardware compatibility l...
mdgm-ntgr
Oct 02, 2012NETGEAR Employee Retired
It should work well with the Duo v2. The "NAS optimised features" you refer to are really just disabling "green" features which if enabled would've caused compatibility issues.
As for the NV+ v1 I've sent some PMs to Han Solo asking for further info on this and am still waiting for a response.
