Rudy_san
Jul 27, 2012Aspirant
WD Red 2Gb Drive (WD20EFRX) compatibility with NV+ v1
Does anyone know whether the new WD Red 2Gb drive (WD20EFRX) is compatible with the old NV+ v1? I see the 1Gb model (WD10EFRX) and well as the old 2Gb WD2EARX listed in the hardware compatibility l...
Sep 23, 2013Guru - Experienced User
Your are correct, it isn't on the HCL - most likely because the NV+ v1 has been out of production for so long. It is on the list for the newer models.
Is your nv+ still under warranty (or under support contract?)
