Rudy_san
Jul 27, 2012Aspirant
WD Red 2Gb Drive (WD20EFRX) compatibility with NV+ v1
Does anyone know whether the new WD Red 2Gb drive (WD20EFRX) is compatible with the old NV+ v1? I see the 1Gb model (WD10EFRX) and well as the old 2Gb WD2EARX listed in the hardware compatibility l...
Sep 23, 2013Guru - Experienced User
That was my recollection as well.
mdgm wrote: Odd. I was sure the WD20EFRX was on the list and now I check and I can't see it there. I can see the WD10EFRX there though.
