Rudy_san
Jul 27, 2012Aspirant
WD Red 2Gb Drive (WD20EFRX) compatibility with NV+ v1
Does anyone know whether the new WD Red 2Gb drive (WD20EFRX) is compatible with the old NV+ v1? I see the 1Gb model (WD10EFRX) and well as the old 2Gb WD2EARX listed in the hardware compatibility l...
Sep 13, 2014Guru - Experienced User
The WD RED WD10EFRX is listed for the NV+ v1, but the WD20EFRX is not. The WD20EFRX is on the list for the NV+ v2.
The WD20EFRX runs well in my duo v1, and if you are not under warranty anyway you might as well go with it.
