WarrenT
May 17, 2019Tutor
WD Red Model EFRX vrs new EFAX
I note that the WD20EFRX (2TB, WD Red) is approved for use in the RN424. However, the newer version of the Red is WD20EFAX, and has more cache (256MB for the EFAX vrs 64MB for the EFRX) and has faste...
May 17, 2019Guru - Experienced User
Netgear is slow to approve new drives. I'd be shocked if the WD20EFAX didn't work in the RN424. FWIW, I installed the 10 TB WD100EFAX in my RN526x a couple of weeks ago, and it is working fine.
WarrenT
May 17, 2019Tutor
Hi Stephen,
Thanks very much for your helpful advice.
Cheers,
Warren
- WarrenTMay 20, 2019Tutor
Hi, Is it possible to set the Power Timer to a finer setting than every hour, eg in 20 minute increments?
Thanks,
Warren
- StephenBMay 20, 2019Guru - Experienced User
Thanks,
Warren
Unfortunately not. It'd be useful to have a finer granularity (1 minute) - for instance if you want to boot up a NAS to receive a backup hosted on another machine.
Thank you. I have two NAS devices both fed from the same UPS. NAS B is linked to the primary NAS A for the purposes of graceful shutdown. Both are on power timer to start at the same time. I get error messages regarding NAS B not being able to communicae with NAS A for a about 15 secs after start up time. Hence ability to start A about 1 minute before B would solve that problem.
Netgear: Please give us granularity for Power Timer to nearest say 5 minute increment.
Thanks,
Warren
