crazychimpjimbo
Oct 13, 2015Aspirant
Web Server
Hi All New to this community! Looking to use my readynas 314 to host a website. Has anyone got any ideas/instructions on how to do this? Thank you!! :)
BrianL2
Oct 13, 2015NETGEAR Employee Retired
Hi crazychimpjimbo,
Welcome to the community!
Kindly check this article for steps on how to create a webserver in your ReadyNAS system.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
crazychimpjimbo
Oct 14, 2015Aspirant
Perfect!!! Next will be wordpress but ill no doubt make another thread when it comes to it!!!
- BrianL2Oct 14, 2015NETGEAR Employee Retired
Hi crazychimpjimbo,
Great! I hope i've been a big help to you. For the wordpress procedure or tips, you may want to create a new thread or topic.
Kind regards,
BrianL
- SandsharkOct 17, 2015Sensei
That article has one major oversight -- the major IP's block port 80 on most non-commercial accounts. So, you have to use an alternate to get around it. When you set up the dynamic IP re-direct, also select an alternate port (I use 50080). Then, at your router, direct external 50080 to internal 80 on the NAS.
- StephenBOct 18, 2015Guru - Experienced User
My ISP (verizon fios) used to block port 80, but that changed a while back. Comcast doesn't block port 80 either.
So maybe test port 80 first (forward in your router, and then use http://www.canyouseeme.org/)
