crazychimpjimbo
Oct 13, 2015Aspirant
Web Server
Hi All New to this community! Looking to use my readynas 314 to host a website. Has anyone got any ideas/instructions on how to do this? Thank you!! :)
crazychimpjimbo
Oct 14, 2015Aspirant
Perfect!!! Next will be wordpress but ill no doubt make another thread when it comes to it!!!
BrianL2
Oct 14, 2015NETGEAR Employee Retired
Hi crazychimpjimbo,
Great! I hope i've been a big help to you. For the wordpress procedure or tips, you may want to create a new thread or topic.
Kind regards,
BrianL
NETGEAR Community Team
- SandsharkOct 17, 2015Sensei
That article has one major oversight -- the major IP's block port 80 on most non-commercial accounts. So, you have to use an alternate to get around it. When you set up the dynamic IP re-direct, also select an alternate port (I use 50080). Then, at your router, direct external 50080 to internal 80 on the NAS.
- StephenBOct 18, 2015Guru - Experienced User
My ISP (verizon fios) used to block port 80, but that changed a while back. Comcast doesn't block port 80 either.
So maybe test port 80 first (forward in your router, and then use http://www.canyouseeme.org/)
